Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2007 Civic - Aux button not working
Old Jul 29, 2020 | 08:17 AM
Gee77's Avatar
Default 2007 Civic - Aux button not working
Hi, just picked up an old civic (2007) 2.2
it has the stock stereo, and has a CD/AUX button which when i press it doesnt actually go to AUX, just stays on the radio.
it doesn't appear to have an Aux input, however there is a cable hidden in the middle of the dash that has a cable with an ipod/usb/3.5mm jack plug
Ive tried plugging a bluetooth adapter into the 3.5mm jack but when i click "AUX" on the dash.. nothing happens,
Any ideas?
Thanks
Old Aug 3, 2020 | 11:48 AM
em689's Avatar
Default Re: 2007 Civic - Aux button not working
Have you considered changing the aux port?
I had a similar (same?) problem with my Civic. The aux button stopped working suddenly. After googling and watching a bunch of YT videos, I learned that the aux button only works if you have an aux cable plugged in, meaning if nothing is plugged into the aux port, then it can't switch from one mode to another, radio to aux for example. So, if you press the aux button and it doesn't do anything, it's likely because the aux port no longer works and to put it in the simplest terms "it can't communicate with the button that something is plugged in." The moment I replaced the aux port, my aux button started working again.
Hope that helps?
Old Aug 3, 2020 | 12:10 PM
Gee77's Avatar
Hope that helps?
Hi thanks for the info.
I don't think mine has an aux port... But someone has modded it with a parrot car kit and in the gap where the aux port should be is a multi plug cable with 3 ends... 1 is 3.5mm jack.. one is iPhone (old style) and also a USB connector (works for powering stuff)
I thought I could just plug something I to the jack and press the aux button but it doesn't seem to work...
I'll take it to get looked at a garage see if they can figure it out thanks!
Gee
Bruce LeRoi
12
Dec 13, 2017 08:36 PM
chrysler kid
18
May 14, 2015 07:34 PM
305_DB7ish
Mar 25, 2015 12:52 AM
kavok
Jan 11, 2014 05:55 PM
ipleadthe5th
Audio / Security / Video
Jul 10, 2011 04:08 PM
