Electrical Issues
Hello!
If you have any ideas about this issue, then please chime in. I cannot figure it out.
I have a 2007 Civic. The car runs great - cranks right over and works like a charm. The only issue I have is with the radio, which died for some reason probably related to the other issue.
The real issue is that when I shut the car off and before I open the door, the power shuts completely down. I cannot put windows up. I have no interior lights. Nothing.
I checked all of the fuses, and they are fine.
Suggestions welcome.
Not the radio; but, the other issues may be caused by a faulty Multiplex Integrated Control Unit (MICU) which is part of the under-dash fuse/relay box. I would still check that power is getting through the fuses with a multimeter or other testing tool first.
If MICU requires replacement, the whole under-dash fuse/relay box is replaced, and registration with HDS is required due to the Immobilizer System.
dadrought6
May 11, 2011 05:11 AM
