How to reset timing if belt breaks. 95 Honda Civic DX
Old Jul 20, 2020 | 01:59 PM
TMania808's Avatar
Default How to reset timing if belt breaks. 95 Honda Civic DX
Hey guys, timing belt broke while I was driving. I ordered a new belt and was going to replace it, just hoping to get lucky that valves didn't bend beyond full overhaul repair. My question is how do I re-time the engine now that timing belt is already off?
Old Jul 20, 2020 | 02:11 PM
muellersfan's Avatar
Default Re: How to reset timing if belt breaks. 95 Honda Civic DX
Old Jul 20, 2020 | 03:19 PM
TMania808's Avatar
Originally Posted by muellersfan
So it looks like under "timing belt installation" step 2: A and B is the answer to my question? With no timing belt on, I can simply rotate the the crank to it's mark, and then rotate the cam to it's mark?
Old Jul 20, 2020 | 07:37 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You actually want to make sure the crank is 90 degrees off of TDC or BDC when turning the camshaft. What this does is put all the pistons half way up or down in the cylinders so that there is zero possibility of valve&piston contact. Once you then have the camshaft on it's mark for #1 TDC, then you can safely rotate the crank to TDC to put the belt on.
Old Jul 27, 2020 | 12:23 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Better check in there before you bother with a new belt.
Old Jul 28, 2020 | 11:33 AM
Spaceturtle917's Avatar
I disagree. If you do a new belt and it runs great then you're good to go. If the new belt doesn't fix it then the timing belts already done when you go to do the head and it's already out of the way.
Ray Hol
Honda Civic (2001 - 2005)
Nov 18, 2014 01:57 PM
tommypilot
Mar 11, 2013 12:29 PM
Kellindal
Dec 1, 2007 02:20 PM
joe91169
Sep 2, 2007 02:39 AM
RA61825
Nov 10, 2003 01:28 PM
