Engine surging 99 accord V6 help
Old Jul 17, 2020 | 09:30 PM
LoganSch's Avatar
Default Engine surging 99 accord V6 help
Once my engine gets warmed up my engine starts to surge and it feels like air or fuel is getting cut off then suddenly regains it even when I keep constant pressure in the peddle. I've cleaned injectors and I've replaced my fuel pump. I have a check engine light for an exhaust restriction(in my cat) and other things unrelated from the surging. I do not see any leaks. Also I have an aftermarket cold air intake which I'm going to put the stock one back on to see if that's the issue but I haven't had an issue with then before. Any help would be appreciated.
Old Jul 18, 2020 | 03:03 PM
99stockcivic's Avatar
Default Re: Engine surging 99 accord V6 help
Can youput a scanner on it and see what appears to be happening when the "surge" happens? Maybe a fuel pressure drop or an air flow drop, or timing changing?
Old Jul 18, 2020 | 04:41 PM
Chris Anderson's Avatar
I have a 99 accord but it's a 4 cylinder. It was surging but only at idle or stopped in traffic but was ok as long as I was giving it gas and moving. It turned out to be my idle air control valve. Don't know if yours is the same. I hope this helps.
scotty1387
Nov 28, 2017 12:01 PM
you_aint_tight
Jan 9, 2014 05:50 AM
pissedoffowner
Mar 8, 2012 07:39 AM
galen
Jul 6, 2010 11:20 AM
venomzz
Nov 10, 2007 03:45 PM
