Subframe brace with ST rear sway bar?
Old Jul 17, 2020 | 05:25 AM
mattkosem's Avatar
Default Subframe brace with ST rear sway bar?
I bought an ST bar for my EG hatch, and sure hope it's gonna fit. Search says it does, but all the info is so old that all the image links are dead.
I see these:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/asr-brace-suspension-technique-sway-bar-2636748/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/can-suspension-techniques-ek-rear-sway-work-asr-subframe-2133706/
It seems like it should work, based on that, but can any kind soul confirm (perhaps with accompanying pics) that it will? I'm gonna have to redo the rear section of my exhaust to clear the bushings, since the Yonaka stuff is in the way, but if the rest bolts up I will be happy. The Truhart brace I have apparently uses the stock mount points, but does space things back a bit, so I'm a scoche worried without seeing/hearing that it actually works.
Will this thing fit?
--Matt
Old Jul 18, 2020 | 10:54 AM
mattkosem's Avatar
Default Re: Subframe brace with ST rear sway bar?
Long story short, it doesn't. It contacts the rear strut bodies so it won't work.
Old Jul 31, 2020 | 07:53 PM
LeetoEg6's Avatar
Thanks for the update man. Someone will find this info useful.
Old Jul 31, 2020 | 08:38 PM
tony_2018's Avatar
Fish Twig
The posts were both about the 'ek', not the 'eg'.
Freemananana
Suspension & Brakes
Jul 24, 2014 10:18 AM
Vagitarian
15
Oct 7, 2013 11:08 AM
owneyboy
Nov 12, 2008 06:24 PM
Forrest Gump 9
Aug 4, 2004 09:30 PM
abolish415
Nov 26, 2003 11:59 AM
