91 ef hatch b20 obd1
Old Jul 15, 2020 | 02:59 PM
Ninjasalsa ef's Avatar
Default 91 ef hatch b20 obd1
Hi all. Been having a real pesky problem with my swap and havenot figured it out yet. Basically have poor idle, i mean crappy. It starts fine then bogs down real low, then stalls. Usually happens when it gets warm, If you give it gas it is fine. Usually run like crap after its warming up which makes me think its an air/fuel metering issue. Possibly after closed loop
smoke tested and brake clean cannot detect any vacuum leaks
iac was relearned
New tps and calibrated
new map sensor
cleaned iac
tried two different fitv
Fuel pressure is there
new spark plugs, wires cap rotor spark is present
Any help is good thanks for reading
Old Jul 16, 2020 | 08:01 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: 91 ef hatch b20 obd1
Double check your mechanical timing and your ignition timing.
Old Jul 16, 2020 | 08:12 AM
GIZZ - EXV's Avatar
Loved
How about... Clean the throttle body if it's dirty. If that doesn't work mechanically open the throttle body a hair.
Old Sep 15, 2020 | 05:49 PM
Thanks guys. I had a loose iat sensor plug that was making a bad connection.
Efhatch1217
Mar 29, 2018 12:06 PM
Jesse Mejia
Mar 27, 2017 08:34 AM
skagitstriker15
Feb 9, 2012 03:32 PM
ej1252
Oct 5, 2011 08:11 AM
