A/C Condenser fan Issues (EK Hatch DX)
Old Jul 14, 2020 | 02:51 PM
Bic_Boy_Sam's Avatar
Default A/C Condenser fan Issues (EK Hatch DX)
Hey there Everyone I have always crunched on these forums for my last two civics and almost always found the answer but this time I seem to have run out of luck...
So ill explain my situation:
I own a 1999 Civic Hatch DX, with no A/C and while it was cooler in my area I was fine but now that the summer has officially hit I Am dying. So i decided to run on over to a local pick n pull and pulled out everything for the AC swap.
parts I pulled:
Condenser + Fan
Compressor (2006 replacement),
Dryer
Lines
pulley
Evaporator + Box
Front engine/ accessory harness
Relays + fuses.
i put it all in over a weekend and i noticed the condenser fan wouldn't kick on so naturally i suspected it was because the relay was bad so i swapped it with my front radiator coolant fan relay and it still didn't work, but when i used a paperclip on the power side of the relay it would run the fan no problem, and the ac would work great. So I know that the wiring to the fan is solid the issue seems to be from the fuse panel to somewhere in the cabin. the next day i I figured the whole ac system wouldn't turn on until the loop was pressurized properly, so i brought it down to my local shop and got it evacuated and recharged to factory spec,
the issue persisted. and I had a weird idle issue where it would have a bumpy idle and in the very low rpm range and almost stall, so i cleaned out the IACV and the idle seems a little better.
I think its tied to the ac fan not coming on to cool down the loop and causing the compressor to turn off and on at a fast rate cause weird idling issues.
any help would be greatly appreciated...
first post btw
Old Jul 14, 2020 | 03:00 PM
muellersfan's Avatar
Default Re: A/C Condenser fan Issues (EK Hatch DX)
I hope you installed a new receiver/dryer. Did shop that evacuated and recharged system ask?
Does the A/C compressor clutch engage when you press the A/C button?
In the fan relay socket, did you jump pins 2-3 or 4-3 to make the fan run?
Old Jul 14, 2020 | 03:22 PM
Compressor does click on
New dryer is installed
I believe pins 3&4
Old Jul 14, 2020 | 03:46 PM
Originally Posted by Bic_Boy_Sam
I believe pins 3&4
Repeat jump test on pins 2-3 with key OFF. Does fan run?
Old Jul 14, 2020 | 04:03 PM
No such luck
Only way that works car on or off
Old Jul 14, 2020 | 04:10 PM
Your hood fuse box or AC diode is bad. Test the AC diode. If it is fine, replace the hood fuse box.
It's no longer relevant, but I told you to do incorrect pin jump tests.
I should have said jump 1-2 or 1-4.
Old Jul 14, 2020 | 04:14 PM
Are you sure?
Is there anyway to verify this easily?
Old Jul 14, 2020 | 04:20 PM
Are you sure?
See my edited post.
And yes, I am sure assuming that you jumped both 1-2 (shown in your pic) and 1-4.
However, the 1-4 test must be done with Key in ON(II). Try that if you haven't already.
Old Jul 14, 2020 | 04:35 PM
No luck
Only jump that works is 1,2 and works with key in or out of ignition
How would I go about testing the diode?
Edit: thanks for the diagram it's much better quality than the one I had previously
Old Jul 14, 2020 | 04:47 PM
Do you have a multimeter? Most modern digital multimeters have a diode testing function.
I believe that the diode is located on the underside of the hood fuse box.
Edit: thanks for the diagram it's much better quality than the one I had previously[
Old Jul 14, 2020 | 04:49 PM
Yes I have one ill pull it apart right now one sec
Old Jul 14, 2020 | 04:52 PM
Disconnect the battery!
Old Jul 14, 2020 | 04:57 PM
I got it open what should I be looking for?
And I did lol thanks for checking haha
Old Jul 14, 2020 | 05:01 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The following shows the location of the A/C diode.
Old Jul 14, 2020 | 05:03 PM
So I should check resistance on those two points on the fuse box or access it from the under side?
Old Jul 14, 2020 | 05:05 PM
The diode is actually on the top side of the hood fuse box. Post pic and I'll circle it for you.
Edit: The famous tech8 beat me to it!
Old Jul 14, 2020 | 05:08 PM
Remove diode from fuse box.
Set multimeter to test diode. It has two pins.One polarity across the pins should yield a reading and the other polarity should not, if diode is good.
Old Jul 14, 2020 | 05:12 PM
The test is done on the removed diode, not the fuse box socket for the diode.
Old Jul 14, 2020 | 05:16 PM
That could be my problem as there was nothing in the socket to begin with I didn't know I needed one when I was pulling parts
Can I pick one up locally (generic auto parts store) or is it a semi hard part to find
Old Jul 14, 2020 | 05:21 PM
PROBLEM SOLVED.
Buy an AC diode (Honda dealer) and install it or return to junk yard to retrieve from donor Civic.
Old Jul 14, 2020 | 05:23 PM
If that's works it would be great! Have a link to the proper one I should buy? From O Reillys or auto zone?
junkyard is closed
Don't wanna mess around and get the wrong one
Old Jul 14, 2020 | 05:26 PM
You can see the Honda part number here:
https://www.bernardiparts.com/Honda/...&assembly=1887
It's part #1.
You can also search for it at local auto parts stores. Not sure if they will stock it.
Old Jul 14, 2020 | 05:32 PM
Great thanks for your help wouldn't have guessed that especially since the diode slot on my 7th gen has nothing in the diode slot and ac runs fine... Kinda weird I'll run down there and see if they have one ill post my outcome
Thanks again!
Old Jul 14, 2020 | 05:38 PM
The 7th generation Civic A/C circuit lacks an AC diode.
