Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Honda Civic 2012 Reverse light bulb change
Old Jul 12, 2020 | 07:31 PM
Carlglenn's Avatar
Icon5 Honda Civic 2012 Reverse light bulb change
Hello, I need some assistance with replacing the reverse / back out lamp on a 9th Gen , 2012 Honda Civic .
Please see pics both on the outside and inside of the boot lid.. however I can't find where the bulb is located.
Would appreciate any advise or clues on how to go about this :-)
Back out light on the outside
Back out light on the inside, but can't see the bulb connectors
Old Jul 12, 2020 | 07:55 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Honda Civic 2012 Reverse light bulb change
There is no bulb where you're referring to. The reverse/back up bulb and connectors are only at the corners.
Old Jul 12, 2020 | 10:55 PM
Carlglenn's Avatar
Thanks for the quick response, so to get to those connectors as shown in your picture do I have to remove the top layer of metal covering all around the boot lid from the underside ?
Old Jul 13, 2020 | 02:07 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
No. You just remove a few plastic clips then pull back part of the trunk liner to access the bulbs.
It is shown in the owners manual which is viewable online for free at North America Honda's website. You're in NZ; but, your Civic should be similar if not the same to access the bulbs.
Old Jul 13, 2020 | 07:15 PM
Carlglenn's Avatar
Well that's exactly what I did was remove the plastic clips to pull down the liner.. however beneath that is the metal fitment as seen in my 2nd picture. I can't see the bulb holder nor any cables which is strange. There is also nothing missing, no holders or anything like it as my lamps are fully functional. The only reason I need to change the reverse lamp is to upgrade it from filament to LED. Perhaps I might try and unscrew those 2 connectors and see if the lamp fitment on the outside will pop out. Perhaps it may reveal the bulb holder ?
Old Jul 13, 2020 | 07:38 PM
Carlglenn's Avatar
Icon5 Re: Honda Civic 2012 Reverse light bulb change
Looks like I'm getting somewhere after some Web research. this fitment doenst appear to be very common and is similar to my fitment, but wonder how its hooked up ?
danir
Sep 20, 2018 03:24 PM
adueisaac
Transmission & Drivetrain
Mar 6, 2014 08:04 PM
Php
Feb 20, 2010 08:14 PM
DeDonDeRosa
Oct 26, 2005 01:58 PM
Cuong-nutz
Apr 8, 2005 11:41 AM
