Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Ruckus Variator grinding into engine crankcase
Old Jul 12, 2020 | 05:34 PM
frankenstein1's Avatar
Default Ruckus Variator grinding into engine crankcase
Any ideas?
2018' stock Ruckus with 1500 miles. Variator is grinding into the engine crankcase at idle. No issue with higher rpm because the inboard variator guide plate expands away from the case due to inertia design. The crank doesn't appear to have any excessive endplay etc and the motor is tight and performs as it should with 1500 miles on it. I noticed that the variator has started grinding into the crank case, crank seal etc. Also, the crank appears to have a shallow groove 1/2 of the diameter of the crank next to the crank bearing and seal? Hmm, seems like there should be a spacer or something in between the variator and crank case?
Old Aug 10, 2020 | 09:18 AM
Mark Allan's Avatar
Default Re: Ruckus Variator grinding into engine crankcase
Originally Posted by frankenstein1
Any ideas?
I have the exact same issue. It looks like you took a picture of mine. Please let me know if you figure this out. Could the drive shaft have been pushed back a little somehow?
Old Aug 10, 2020 | 09:48 AM
So, is what I have done is purchased an extra thick about 1/8" spacer,shim,washer from the local hardware store that fits the crankshaft perfectly. By doing this it spaces the variator away from the case and has worked perfectly now for about 100 miles. We'll just have to see how it works long term.
Old Aug 10, 2020 | 09:53 AM
Mark Allan's Avatar
Thanks. I thought of doing the same thing. And might considering it worked for you. I just wish I knew why it happened.
Did you do any work on it that might have caused it? I replace the variator rollers and the drive belt.
Old Aug 10, 2020 | 10:04 AM
We bought it from a friend knowing that it had a problem. Zero engine work that I know of. That said, it has worked for us but am wondering long term. Considering this I bought a back up motor off of Facebook for $220. But it is working great for the time being. A little difficult in finding the correct fitting fat washer or shim.
Old Aug 10, 2020 | 10:06 AM
Mark Allan's Avatar
Ok. Thanks for getting back to me. Where did you end up getting the washer from? Hardware store? Autoparts store?
Old Aug 10, 2020 | 10:11 AM
Local Ace hardware store had a pretty impressive supply of hardware to look through. Spent about 30-60 minutes in trying to find the best fit. I wouldn't recommend using more than one spacer,washer as it could create extra friction. Going about 1/8th" worked for me and didn't push the belt out of alignment with the clutch.
Old Aug 10, 2020 | 10:31 AM
Mark Allan's Avatar
Awesome. Thanks
Old Aug 10, 2020 | 10:53 AM
If someone could possibly braze or weld the spacer to the back of the variator plate that would be a better option if possible. If my current spacer fails that is what I will do and wish that I did. Best of luck either way!
Old Sep 15, 2020 | 06:44 AM
ruckus_'s Avatar
I have the same issue just starting to occur (not quite advanced to this level) on my ruckus. I'm contemplating using an SKF 99055 Speedi-Sleeve on mine as a stop-gap fix to prevent further damage until I can do a crankshaft repair.
Old Jun 3, 2023 | 09:14 AM
batikanince's Avatar
Having same issue what do you guys suggest?
fastdohc
Jul 23, 2010 07:22 PM
88crxdxfastwhip
Mar 18, 2007 05:16 AM
hondaeg8
Feb 9, 2004 10:42 AM
flat-blk-HB
Jan 13, 2004 07:26 PM
