Transmission & Drivetrain Gearboxes, Differentials, Clutches
4th gear keeps breaking
Old Jul 12, 2020 | 02:16 PM
jard1411's Avatar
Default 4th gear keeps breaking
I have a built b18 on 30 psi maybe around 400whp
my transmission is a 90-93 cable ls tranny and I've shredded 4th gear twice now
what could be causing this to happen a bad bearing, fork, or shim?
should I just run a 5th gear cuff?
Old Jul 12, 2020 | 09:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 4th gear keeps breaking
Your problem is 400 whp... and the torque that comes with it when making that level of power on a non-VTEC B18. A cuff may help, but ultimately, you need stronger 3rd and 4th gears to slow down the frequency of failure.
Old Jul 13, 2020 | 09:07 PM
Aquafina's Avatar
You're making more power than the gears can hold. A cuff won't help, you'll need a 3/4 gear set. Is it the 90-91 trans or 92-93?
Rickvanuden
Jun 8, 2017 09:00 AM
Rickvanuden
May 13, 2017 05:09 AM
torr
May 22, 2005 03:49 PM
teg9
Jan 19, 2004 09:38 PM
Vracer111
11
Dec 18, 2003 09:04 PM
