Its a brand new comp clutch stage 3. Total driven miles was about 3. Long story short transmissikn shop said clutch slaves wasn't disengaging the clutch that's why it turned out like this. You can see it but barely feel the scratches. Any input would be greatly appreciated.
What does the flywheel and pressure plate look like ?
Flywheel is getting resurfaced at the machine shop right now. They just called and its still usable. Flywheel wasn't bad at all.. you can see the marks but also can't feel it. Ill attach an image of the pressure plate.
I already ordered a replacement clutch but if this is still ok to use ill save it. I have a spare ACT pressure plate here than I can use. BTW the flywheel was a 12lb ACT.
