2000 Civic D16 ticking sound with video, held ID issue
2000 civic with ticking issue and slight vibration noticeable on pulley
bottom end? Valve adjustment? Skipped timing tooth/valves hitting? Any help greatly appreciated
It just started slowly and keeps getting worse. I am no longer using the car in case it is anything bad, but it just started making the noise one morning when turning it on, I assume it was doing it before but it may not have been audible so not sure how long it has been doing it, but it started getting louder pretty quick, and now its parked.
Either the crank pulley is coming loose
or the crank spun a bearing or is about too cause its wobbling pretty good.. check the 19mm crank pulley bolt or if its even still there!~
I found out what it was, it was the pulley, not loose or anything, but the damper part, the bushing (is that what its called???) Within that dampens is what made it wobble and tick, hopefully got it in time without any other major things going bad.
thank you all for your support
They still sell new OEM crank pulleys and its a very good investment even on a used engine! if you have the funds I recommend buying a brand new OEM pulley.
