The thermostat ground shocks me
Old Jul 8, 2020 | 12:57 PM
1320vickers's Avatar
Default The thermostat ground shocks me
Like it says I’m trying to find a short that’s causing the ecu to only have one light and the main relay and icv buzz continually. The ground has shocked me 2 times I don’t see how this is happening or where the shirt could be
Old Jul 9, 2020 | 07:38 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: The thermostat ground shocks me
What do you mean it shocks you?
How are you looking for the short?
What tooling are you using?
Old Jul 9, 2020 | 08:02 AM
I was using a multi meter checking for continuity and looking for what I’m guessing is a break in the harness When I touch the therm ground wire the buzzing gets louder then it shocks me like the wiring in a house shocks you
Old Jul 9, 2020 | 10:07 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Change your meter reading to voltage, put the positive end on the positive battery terminal and the negative end touch the thermostat ground, What is the reading?
Old Jul 9, 2020 | 01:34 PM
I am right at 13 the main relay and icv buzzing gets worse when you mess with the ground everything I’ve seen says it’s from a.ground off somewhere
Old Jul 9, 2020 | 01:49 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Now put 1 meter lead on the negative battery cable and the other lead on the tstat ground. Now what is it?
(car should not be running,but the key should be on)
Old Jul 20, 2020 | 04:39 PM
crazyhorse2011's Avatar
10 Year Member
Loved
R.I.P OP, he ded
Old Jul 21, 2020 | 07:38 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Originally Posted by crazyhorse2011
R.I.P OP, he ded
LoL guess so.....
Old Jul 24, 2020 | 08:22 PM
muellersfan's Avatar
It's unlikely that you have a short to ground. It's much more likely that you need to clean the transmission and battery ground connections.
j.dizzle
May 6, 2007 04:25 PM
defcon
Apr 30, 2007 05:40 PM
Daikirai
Sep 22, 2003 08:07 PM
civickidd99
Aug 11, 2003 08:35 AM
Integra187
Feb 1, 2002 09:52 PM
