For sale :
2000 Honda Civic Si
Clean NC title and clean Carfax
191xxx miles runs and drives great . . car is what I’d say 99% bone stock
heat, a/c power windows and sunroof all works like it should I believe the driver side door needs a new door lock actuator but can be locked with key . .
interior bone stock all the way down to the floor mats
The bad . . Car needs to be PAINTED. . And one of the tabs on left headlight is broken . .
Needs B-pipe and axle back muffler replaced . . Might fix the exhaust before I sell . .
my plan was to do a em1 restoration. . Which this car I belive is a great candidate. .
asking price is 6200 . . Thanks for looking
I will be working on photos and making them right with a sign and profile name and date
Had the valve cover re done
Has some wear on drivers seat . .
Factory installed wing
Condition of paint on roof Might be hard to tell . . Hood needs some paint . .
Do you know how the headlight tab broke? Seems to be an odd thing to break if the car is accident free. Not making an accusation, just seems unusual.
Can you comment on how the car runs? Have you done a compression test since you’ve had it?
thanks-James
Im not sure what happened to the headlight tab . . I know the left front fender was removed by a repair shop according to some receipts that I got with the car . . I’ll get a better pic of it . . I haven’t done a compression test . . The car doesn’t smoke or leak oil . . Runs good . . Transmission is smooth in all gears . .
I’m not saying that . . I have no way to prove that is or isn’t . . I believe it is original . . but it’s a brighter red under the hood along the fender channel. .
the fenders also have vin tags so you can tell very easily
