F22B1 distributor on F22A2
Hello! I have an F22B1 OBD1 distributor, my engine is an F22A2 sohc non-vtec ('92 prelude- internal ignition coil) pretty similar to the F22A1 found in Accords. Anyone knows if the B1's distributor fits in my A2? Thanks
Type both cars into here and see if the part number is the same:
https://www.partsgeek.com/mmparts/di...da/accord.html
This is a H Series internal coil, one corner looks significantly larger than the other two:
In the list there are some F22a1 distributors with external coil. And they look like this:
All three sides look the same length. The only difference with my F22A2 it's the fact that mine is with internal coil.
This is the F22B1 distributor that I have. The holes kinda look in the same place of the F22A1 dizzy of the website.
Looking all distributors of the website they all have the same two plugs, differing among having 8 or 7 pins between internal and external coil.
And look like they are like the F22B1 dizzy
However I don't know if the wiring is the same. So if anyone knows and could tell me it'd be awesome. This is also an Hitachi dizzy. I'm in total lockdown and I don't have my lude here to compare it directly. All the help will be appreciated
So I know this thread is getting old, but I just swapped a f22a6 in my cd5 that had a f22b1, did that distributor work for you at all, im going nuts. I want this swap to be plug and play as much as possible.
