1997 Honda Civic Dx crank no start
Old Jun 30, 2020 | 09:36 AM
SeanSmith24's Avatar
Default 1997 Honda Civic Dx crank no start
Car ran fine till I parked it for winter. Went to start this year and would just crank and crank but not start. Had a code p1381 but was just intermittent so I checked wiring, dizzy, pcm/ecm, main relay and couldn't find anything. Im stumped any suggestions as to what it could be? It's a manual not automatic
Old Jun 30, 2020 | 12:00 PM
muellersfan's Avatar
Default Re: 1997 Honda Civic Dx crank no start
From the unplugged ECU connector, Ohm test the CYP sensor.
Old Jul 1, 2020 | 09:55 AM
What should the resistance be? I've checked continuity and ohms at the dizzy and ecm. One mechanic gave me specs but they were different than the ones in the service manual I found for the car
Old Jul 1, 2020 | 11:24 AM
Post the ohm readings for all of your tests.
Old Jul 4, 2020 | 10:25 AM
I was getting something like .350 ohms. Service manual I went off said it should be between .350 to .700. I ripped the harness out and checked for broken wires etc and didn't find anything. Car won't even start with starting fluid
Old Jul 4, 2020 | 12:38 PM
You also need to check the two CYP sensor pins in the ECU connector for a short to ground.
Old Jul 4, 2020 | 04:51 PM
I did. Measured from ecm and from the dizzy. Measuring from the ecm gave me some wonky readings though. Like nothing remotely. Currently im thinking it's the CKP sensor but I never had a code for it
Old Jul 4, 2020 | 05:12 PM
Post a video showing what "wonky" means.
If the CYP sensor Ohm reading is fine and there's no short to ground on either wire, then replace the ECU.
frankmosqueda
Sep 18, 2018 04:08 PM
1sik_90hatch
Dec 18, 2017 09:01 PM
