starter smoking!!
Hi so i replaced my wifes transmission on a 2004 honda odyssey. Everything went smooth until the end. So i hooked everything back up where its supposed to go the ground strap and all even starter. I put positive cable on then went to hook up the negative side and it sparked and the main wire that hooks onto starter started smoking. so i decided to try again and see if i can tell so i went to put negative on and when i did the cable practically melted to post and the starter smoked again. What is going on. I replaced the transmission and a starter came with it so i figured i would just leave it our old one was great could it be a faulty starter? need to fix asap thank you
You have something hooked up wrong. Post pictures of the starter.
Should only be a positive lead from the battery to the starter. Ground for the starter is the body of the starter bolted to the engine.
So i ended up just swapping the starter with my old one and its fine now. Now my problem is shifter wont move. when i turn key to on position it says drive but cant move anything if i go underneath and move it manually still nothing what has gone wrong?
C Keller Nino
Feb 16, 2020 12:11 PM
justYncredible
Apr 22, 2018 11:03 PM
