Hello guys I need help to hook up my speed sensor on a B20v using p28 Ecu the connector is completely off and I can fine the actual why to hook it up back I got 3 wires on the connector , black. Black&yellow. Blue&white
Pic of the actual connector. thanks for help cheers!
Look on the engine harness to where it got cut off from, can you locate where the speed sensor was cut? it would be as simple as soldering the wires back together matching the colors.
