F22 Crank inside a JDM H22A Block
Hi all,
So i've recently taken my engine out after a major failure and plan to rebuild it, for refernce its a 95 H22A 2.2l JDM honda prelude. The crank is worn beyond repair and i cannot source another H22A Crank anywhere (even with shipping costs, located in UK).
I've read up that you can use a F22 crank in place which i can find a few of locally, im planning on putting forged pistons and con-rods in the block and so i assume i will need them matched to the spec's of a F22 crank or are the 2 totally interchangle?
I.E will i be able to place aftermarket Pistons and rods specifically meant for a normal H22A block or will need to start looking for difference forged F22 rods?
Thanks,
Thanks,
