Rpm drops after HTS basemap
D16Y8, manual, P28, HTS basemap. It runs perfect and idles fine, but when I let the gas off and pressing the clutch (no load on the engine), the rpm drops to 0, sometimes the car shuts off and sometimes it recovers itself.
What can I do to fix it through HTS or some mechanical stuff, like adjusting throttle screw or advance ignition with the distributor or something?
Thank you.
Thank you.
Let me see if I got you. Engine running, unplug the IACV, adjust the screw, and than reconnect the IACV. Doing all this while the engine is running, right?
Setting the base idle speed is a bit tricky because the engine will want to die at 450 rpm. If necessary, carefully press the throttle pedal to keep the engine from stalling during the procedure.
Use an external tachometer because the cluster tachometer is inaccurate at low rpms.
RACEPAK
Aug 27, 2007 02:51 PM
preludexl
Feb 6, 2003 10:32 AM
