Started engine broke with high comp/hard springs
Old Jun 20, 2020 | 04:53 PM
Pablomg's Avatar
5 Year Member
Default Started engine broke with high comp/hard springs
Hey, someone has any problem with the starter engine?I have broken it in half after about 30 times of startup, is there something reinforced on the market or do I understand that it was defective due to the 21 years?
I have B20v 12,7:1 and supertech 85 lbs
Old Jun 20, 2020 | 07:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Started engine broke with high comp/hard springs
LOTS of engines have high compression and high rate valve springs... and do not have starter failures. You either have a bad starter or a flywheel problem that is causing undue stress on the starter.
bjizzle07
Honda Civic (2006 - 2015)
19
Jun 9, 2008 05:47 AM
asianalbutt
Oct 23, 2005 11:38 PM
Wazup
Suspension & Brakes
Sep 7, 2005 05:14 PM
