97 - 01 CRV parts ~selling All Together "Not Seperate" im here in Los Angeles
Misc brand new 1997 to 2001 CRV parts ~ Rack/Pinion Tie Rods, mounts etc.
SORRY WONT Seperate, Price is still $500 if you dont want everything.
PRICE "NOT" negotiable, Understand that the Brand New Rack/Pinion and a Brand New Prothane Bushings Set cost more than $500 already and your getting more for your money.
Google Pickup Location 91303
**When Ready Message me with your number and ill give you directions.
Cash Pickup Price $500 FIRM (WONT Seperate, SORRY) + Shipping & paypal fees,
I can Ship them, "try" to put everything in the rack/pinion box, because of the weight/size it will cost around $150-$175 in 48 contiguous states, I have some reference here & paypal verified for a while.
**Unless Noted ~ All Parts Below are Brand New.
a) Power Steering Rack/Pinion
b) Left and Right Tie Rods
c) Urethane Rack/Pinion Red Bushings
d) 2 Fuel Filters
e) Ignition Switch Wiring Harness
f) Oxygen Sensor
g) Hook for Sunvisor
h) A/C Receiver/Dryer Filter
i) Accessory Belts all 3 (A/C, PS & Alternator)
j) Thermostat with Gasket
k) Stage 2 Clutch & Preassure plate (6 damper springs)
l) Lower Front Left & Right mount
m) Rear Trailling Arm Bushings Left & Right
n) 2 Upper Front Balljoint
o) 2 Lower Front Balljoint
p) Prothane RED Bushings set (82021)
q) Air Filter
r) Rear Main Seal & Cam Seals
s) Upper and Lower Radiator Hose
USED Parts Below;
1) USED Front Lower Control Arms with NEW Bushings
2) USED OEM DC2 ITR Flywheel (15lbs)
3) USED K&N Air Filter
4) USED 1998 OEM Trunk Cover w/Rods and 4 grommets (Needs re-stitch on the right)
d) 2 Fuel Filters
f) Oxygen Sensor
q) Air Filter
USED Parts Below;
TwoFaced
Feb 9, 2011 07:50 PM
