Suspension & Brakes Theory, alignment, spring rates....
Caliper piston not moving inside
Old Jun 18, 2020 | 05:37 PM
455rocket's Avatar
Default Caliper piston not moving inside
Hello
Was all happy today in doing complete rotors and pad break job on an Accord 2005. Seems there was a lack of brake maintenance, but anyhow on the first wheel, the piston decided to play tricks on me.... it won't retract back inside.
I can turn the piston clockwise but it results in no sliding movement. However, if I turn it counter-CW, the piston moves forward (towards me) and same if I press the break pedal.
So it seems something prevents it to move inwards.
Tried compressing it with the tool but it doesn't want to move either.
Anyone can help in explaining what is causing this and if it either needs rebuild /replacement ?
Thanks!
Old Jun 18, 2020 | 07:16 PM
Tyson's Avatar
Default Re: Caliper piston not moving inside
Rear caliper?
Keep twisting.
Old Jun 18, 2020 | 07:58 PM
455rocket's Avatar
Yes sorry I should've stated it was a rear caliper.
I gave it already like 20 full turns. Does it really need that much ?
Trying to find caliper internal diagrams to understand what is the effect of twisting.
Old Jun 19, 2020 | 01:50 PM
egsleepercivic's Avatar
push and twist, it can feel like for ever before it starts going in lol
Old Jul 24, 2020 | 04:56 PM
Accordian47's Avatar
10 Year Member
Check your parking brake mechanism, it may be partially applied or stuck. The piston moves when twisted because of the parking brake mechanism actually. There is a cam type groove cut into the outside wall of the piston (internally) and the parking brake lever has a pin that it rides in it.
Try actuating the lever on the caliper on and off, maybe even turning the piston while doing so.
Old Jul 26, 2020 | 09:35 AM
455rocket's Avatar
Appreciate the feedback guys.
Indeed it just needed LOTS of push and twist and it managed to go in.
@Accordian47 This is very good information about the parking brake mechanism too, thanks !
Integra4lyfe069
Dec 11, 2011 05:43 AM
kidcool1977
Nov 30, 2008 05:42 AM
93CamaroLT1
11
Jun 14, 2006 09:23 PM
ibe2fly
32
Jul 7, 2005 04:09 PM
harryg
Feb 13, 2003 05:05 AM
