Cabin noise after replacing timing belt
Old Jun 18, 2020 | 12:41 PM
macelodeon's Avatar
Default Cabin noise after replacing timing belt
Replaced timing belt/waterpump/tensioner for the first time, everything seems to be tensioned properly, double checked the timing with a timing gun, everything seemed fine, only issue is a really loud vibration noise only in the cabin, double checked my engine mounts and they seem to be okay. I did find a ground lead running to the shock tower, but I don't know what it attaches to, don't think this could be my issue. I also replaced the torque mount on the one side which has a harder rubber than the old ones, but I dont think it should make THAT much noise. The vibration is most prevalent when you rev the engine, but it doesnt sound like a knock, and i did have the car on the ground and had the same noise. Any ideas?
Here is a video of the car running:
Any advice/ideas would be great.
Old Jun 18, 2020 | 12:43 PM
tony_2018's Avatar
Fish Twig
Default Re: Cabin noise after replacing timing belt
Its idling at 1k rpm, and there is no performance gains from removing the timing belt cover.
Old Jun 18, 2020 | 12:57 PM
muellersfan's Avatar
Tension the timing belt as detailed in your service manual.
Old Jun 18, 2020 | 12:58 PM
macelodeon's Avatar
Car has always idled a bit high, used to be at 3k rpm before I fixed that. Previous owner didn't install the TB cover so I don't have one, car has been running fine w/o it for over a year now, I understand that there's a little bit of risk running it like that but it shouldn't effect anything performance wise.
Tension is fine, followed the proper steps, plus a service manual wouldn't help much as is a LS/VTEC engine swap
Old Jun 18, 2020 | 01:01 PM
Why risk destroying the engine? Scout some local junk yards for missing parts as an insurance policy.
Old Jun 18, 2020 | 01:03 PM
Post in the Hybrid engine swap forum where the LS/VTEC knowledge base exists.
Old Jun 18, 2020 | 01:44 PM
chrysler kid's Avatar
Did you put the keyway back in the harmonic balancer when you installed it
emfman
Jan 12, 2024 12:50 PM
wdraughn
Honda Civic (2001 - 2005)
Dec 1, 2010 06:16 AM
Nutcase4life
Oct 24, 2007 10:48 AM
bam181
Aug 20, 2006 05:16 AM
chowdaa
Apr 15, 2006 05:32 PM
