Flasher relay
The turn signal/flasher circuit is integrated as part of the Multiplex Integrated Control Unit (MICU). The MICU is part of the under-dash fuse box. It does not have the traditional turn signal relay as in older generation Hondas.
The MICU is built into the under-dash fuse/relay box; replacement would be the whole box. MICU controls a lot of things.
What is wrong with it? If there is nothing wrong with the MICU and you're just having an issue with hyper-flashing from using aftermarket LEDS, then you can use load resistors at the turn signal wiring.
yeah I only checked the back passenger blinker bulb because it was the only one the blinking fast. I will check all the other ones. Thank you for the help.
Jimmy
May 29, 2011 04:12 PM
Hollwood050
Jul 8, 2006 08:01 PM
