Transmission and final drive for for drag racing?
Old Jun 17, 2020 | 08:47 PM
Javi_built's Avatar
Default Transmission and final drive for for drag racing?
What’s up guys I’m currently building a B20v motor should make anywhere between 260-270Hp all motor on M5 and around 350-400hp on nitrous, I was wondering what transmission set up should I go with for drag racing not to sure what to go with but definitely don’t want to be going into 5th gear before the 1/4 I’ve heard everything from a b16 trans with a 4.7 final to a gsr with a 4.9 final does anyone have any experience with these type for transmission set up for all motor? Also going with 23” slicks
Old Jun 17, 2020 | 11:40 PM
Aquafina's Avatar
Default Re: Transmission and final drive for for drag racing?
Need to know your rev limit.
Old Jun 18, 2020 | 05:33 AM
Javi_built's Avatar
Most likely 8600-8800 depending on where my tuner wants to set it
Old Jun 18, 2020 | 06:45 AM
AZ_CIVIC's Avatar
Rev limit seems a bit low for drag racing and a higher HP all motor build. If you're only planning on running a stock trans go with a GSR.
Old Jun 18, 2020 | 07:14 AM
civic-steve-94's Avatar
On my old turbo setup which made 321whp on the dyno, I had a 00 civic SI trans attached to it with a 4.40 final drive. I was shifting at 8,750 rpm and was hitting the rev limiter in 4th before the end of the 1/4 mile. That was with a 1.60 60' and an E.T. of 11.69@117mph on 23" slicks.
Old Jun 18, 2020 | 12:08 PM
Javi_built's Avatar
With stock final drive?
Old Jun 18, 2020 | 01:47 PM
Yes factory final drive, here is a list of Honda b series final drives and gear ratios.
Specnically Speaking: B-series Gear Ratio Guide + More!
Teamdiesel
Dec 16, 2007 05:21 PM
cpforyou
Dec 27, 2005 09:21 AM
Chuck P
May 1, 2004 08:24 PM
blazin
Mar 2, 2002 09:49 PM
itr1236
Nov 15, 2001 04:50 AM
