ACG 15 A fuse blowing
Hi. I'm struggling with ACG fuse grounded. Could anyone help me. I need that fuse diagram. My car is a Honda Civic 2012 LX. My car start but I have check engine light, VSA light and power steering light.
I have tried different ways. Disconnected the fuel pump, main relays under the dashboard, all the relays under the hood, electric power steering module, ecm module, vsa module, alternator, ac, maf sensor, map sensor, purge valve, etc. Any idea?
Under-dash Fuse No. B2 (IG1 ACG) protects the following circuit/components:
- Brake Pedal Position Switch (Cruise Control)
- CMP Sensor A (Si)
- ELD (USA, Canada; Si)
- EVAP Canister Purge Valve
- MAF Sensor/IAT Sensor
- Reverse Lockout Solenoid (Si)
- Secondary HO2S (Sensor 2)
RedGSR
May 13, 2003 01:14 PM
