Engine swap from a j30a to a j35 in a 05 accord
I want to put AJ35 3.5 L engine in my 3.0 L accord is that possible it seems like they already have a Turbo stock so they probably handle a Turbo a little better than AJ30 correct?
If I can get some help on this please send me any feedback possible
Thanks Chris
Thanks Chris
it's not magic on the inside. just more displacement. there have been many successful turbo J35 builds, yes. Search for more details about specifics, but yes an Odyssey J35A should be bolt-in. you may need to do something about the ECU- maybe FlashPro will do the trick. it's doable.
it's not magic on the inside. just more displacement. there have been many successful turbo J35 builds, yes.Search for more details about specifics, but yes an Odyssey J35A should be bolt-in. you may need to do something about the ECU- maybe FlashPro will do the trick. it's doable.
v4lu3s
Mar 28, 2012 06:20 PM
