Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Should Drive Face be loose
Old Jun 15, 2020 | 04:28 PM
Mark Allan's Avatar
Default Should Drive Face be loose
Hi,
I went to replace the belt on my sons 2012 Honda Ruckus when I found that the previous owner had driven the "Starer Ratchet " on to the "Drive Shaft" so the teeth on the Starter Ratchet split the teeth on the Drive Shaft right up the middle.
I had the pry the Drive Face off and replace it after filing down the teeth on he Drive Shaft enough that I could slide the Drive Face back on. Now my the Ruckus rattles badly at idle. Not when under load. I can wiggle the Drive Face. Is that how it is supposed to fit.
I'm just trying to figure out if I need to replace the Drive Shaft and Drive Face again.
Thanks from a very frustrated Dad.
Old Sep 15, 2020 | 05:59 AM
ruckus_'s Avatar
Default Re: Should Drive Face be loose
no, it should not fit that way.
everything should be sandwiched tightly together when the crankshaft nut is torqued onto the crankshaft. The only thing that should move independently of the crankshaft is the variator itself.
snowbird6
Feb 26, 2016 09:44 AM
stn-vik
Feb 16, 2012 06:44 AM
