6th Gen Body Question : Front bumper skin boltable between 98-2002?
Hey, I have a question for you 6th Gen Accordians.
A friend of mine damaged her 2001 Coupe front / rear bumper in the rain. They're damaged visually (a spin) but no actual structural damage. Anyway, I found a guy with a 2000 front coupe bumper in the same color. He says that it WILL NOT bolt up correctly to the 2001 mount points. Is this true? Was there a minor front fascia change that I'm not aware of? Or is he mistaken? Thanks!
[Modified by RotaryBzzz, 6:43 PM 11/16/2002]
it will fit, there are several guys at v6accord.com that have done it. They say the mounts are a little different but w/minor alteration will fit.
Yeah you can do it but you will have to drill a couple of holes. very easy for anyone with a little bit of mechanical inclination.
correct assumption. you can really get away without doing it. tehy are the same on the top. it's just the bottom thats different. i haven't had clips on the bottom of mine in quite some time, so you don't really need them.
the grille would line up tho'
01-02 have mold in grille thing..
and there a piece of fat *** metal there for support..
I guess you can try it.
dai
Mar 24, 2005 07:02 AM
8o8da9speed
Jul 5, 2004 03:43 PM
