Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 accord -no power
Old Jun 9, 2020 | 07:25 PM
Cmjb13's Avatar
Default 2007 accord -no power
Have a 2007 accord v6 sedan
Came home from store and turned off car
Tried turning it back on and nothing....
No power. No interior lights, no horn, no nothing
I turn the key and silence. Nothing
Battery was purchased in December from Advanced Auto parts. Not sure if it’s the battery or not.
I’ve also read that it could be be a blown 100a main fuse. Is there a way to test the fuse with a multimeter?
I’m open to changing the fuse, but I’m correct in saying that the fuse will likely blow again until the underlying issue is resolved?
If the fuse is blown, would the car start if I get a battery jump?
Old Jun 11, 2020 | 05:40 AM
Eugene1979's Avatar
Default Re: 2007 accord -no power
check all connections to the battery. got a multimeter? check the battery voltage. I've had AAP batteries fail but not as drastically as yours.
visually check all fuses and fusible links under the hood. check and clean the ground wire and its connection to the car body
start with basic easy stuff.
NorthernB
Jan 4, 2018 07:46 AM
justinm410
Apr 8, 2016 06:45 PM
wetzelman1
Apr 7, 2010 04:32 PM
