Cruise Control does not turn on
Old Jun 7, 2020 | 09:02 AM
siman00's Avatar
Default Cruise Control does not turn on
Hello all I'm a newbie here and need some advice. I have a 2000 Civic si, with 207K miles, 100% stock. Everything is good, but the Cruise Control just stopped working a few days ago. I've checked fuses and see no issue there. The button on the dashboard does not energize, making me think it's the main switch. Is there a quick and dirty way to determine if the switch is bad.
Second question--what is the best way to remove the switch?
Appreciate any suggestions you may offer.
Old Jun 7, 2020 | 09:18 AM
muellersfan's Avatar
Default Re: Cruise Control does not turn on
Does the light in the main switch turn on when pressed?
Old Jun 7, 2020 | 09:19 AM
siman00's Avatar
No, it does not..
Old Jun 7, 2020 | 11:16 AM
Use a multimeter to check 7.5A dash fuse 14.
Old Jun 7, 2020 | 11:21 AM
siman00's Avatar
Will do later today or in the morning. I'll reply with findings. Thank you.
Old Jun 7, 2020 | 11:27 AM
The best way is to test the installed fuse on both top test tabs. Both tabs should show battery voltage with the key in ON(II).
Old Jun 7, 2020 | 11:32 AM
siman00's Avatar
Thanks again, mullersfan. I'll do it exactly like that.
Old Jun 7, 2020 | 01:02 PM
chrysler kid's Avatar
There is no light in the switch,(if there is I've never seen one work) the light turns on in the cluster after the switch is pushed down and the set button on the steering wheel is pressed
There is a rubber stopper on the clutch pedal to tell the cruise control unit that the clutch pedal is not down. When you push down the clutch the switch is engaged and turns off cruise control
Check the rubber piece on the clutch pedal assembly that is suppose to push down on the switch
Old Jun 7, 2020 | 01:06 PM
Old Jun 8, 2020 | 03:27 AM
tony_2018's Avatar
Fish Twig
There is a cc switch, its near the ac vent on the driver side. And yes it lights up but some times the light is burnt out. The switches on the steering wheel are to enable/adjust spd/cancel cruise control. Brake switch and clutch sensors can also cancel cruise control.
Old Jun 9, 2020 | 07:38 AM
spAdam's Avatar
Loved
Community Favorite
Typically when the cruise suddenly stops working it's this stopper. Look for plastic debris on the floor that looks like hard pieces of white or dark blue crayon. When the stopper breaks and falls out, the system is basically always stuck in cancel and will appear to not be able to activate.
Old Jun 9, 2020 | 07:39 AM
spAdam's Avatar
Loved
Community Favorite
Old Jun 9, 2020 | 11:54 AM
siman00's Avatar
Thank you! Thank you to all who offered suggestions. It's working. Turns out it was the little rubber bumper above the clutch pedal. The "penny" tryick fixed it (tape a penny to the stop).
Thanks to a great bunch of guys!
Old Jun 10, 2020 | 06:50 AM
I edited it right after posting
The light in the switch does not affect cruise control functionality, as I have never had a car that has a functional light in the switch
Old Jun 10, 2020 | 08:37 AM
The light is extremely useful for diagnostic purposes. If it turns on, you know immediately that the switch gets power. If cruise control does not work and the switch light does not turn on, it tells you to start your troubleshooting by testing for voltage at the switch connector.
Old Jun 10, 2020 | 09:32 AM
siman00's Avatar
Just FYI, my light on the switch does work.
Old Jun 10, 2020 | 11:59 AM
No, it does not..
I guess something changed along the way.
Old Jun 10, 2020 | 12:03 PM
siman00's Avatar
Yes. The penny trick solved the problem.
Old Jun 10, 2020 | 12:07 PM
The penny trick on the clutch pedal CC switch would not affect whether the indicator light in the main switch turns on or off.
It would only affect whether the CC light in the cluster turns on.
Old Jun 10, 2020 | 12:11 PM
FYI -- The comment is still in your post.
Old Jun 10, 2020 | 11:19 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
OP might not have known to turn the key to ON (II) to test the main switch.
Old Jun 11, 2020 | 03:46 AM
Possibly. I simply corrected contradictory and erroneous information in this tech thread.
dewayne33us
Jan 31, 2010 10:19 AM
MyEfSi2Slow
Sep 18, 2008 08:59 PM
DB_2o3
Sep 13, 2008 01:14 PM
amb4081
May 12, 2006 10:18 AM
white_98_gsr
Audio / Security / Video
May 29, 2005 06:45 PM
