Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Car won’t start after SRI install
Old Jun 5, 2020 | 05:14 AM
Jakgnar's Avatar
Default Car won’t start after SRI install
bought injen sri installed it everything went smoothly started it up and car ran good for a solid 10 seconds, after it bogged out and car won’t start. So i installed the stock intake back took off battery terminals to reset the computer and car still won’t start. I’ve checked all the vacuum lines and MAF sensor seems to be in good shape. The car is turning over just won’t get going, Any ideas of what it could be?
Old Jun 27, 2020 | 02:18 PM
Jeff Hongg's Avatar
Default Re: Car won’t start after SRI install
Hi, I was wondering if you figured out the solution to your problem! I will be waiting!
Old Jun 30, 2020 | 06:22 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you have an OBD2 scanner you might have a code "pending". This might help you isolate what got messed.
Old Jun 30, 2020 | 09:46 AM
Ryanthegreat1's Avatar
My guess is MAF. They don't run worth anything when the MAF gets installed incorrectly or damaged.
Old Aug 31, 2021 | 07:40 AM
White18LX's Avatar
Hey not sure if you are still having issues, but I installed the same intake and had similar issues. Turned out I installed the intake tube backwards(lol). It fits perfectly either way. The injen intake slots the MAF sensor only one way, and the way I installed it had the MAF sensor facing the wrong direction. I flipped the tube so that MAF sensor was facing the correct direction and all problems went away immediately. The arrow should be pointing away from the filter for reference.
Old Aug 31, 2021 | 06:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Thank you for adding your experience and solution to this problem. Many don't... this allows future searchers to find your response and fix a similar issue without creating another thread. Great Job.
iphatcrxi
Sep 16, 2004 09:20 AM
