Help
Old Jun 3, 2020 | 08:09 PM
Michael Burrows's Avatar
Default Help
I have a 98 Honda Civic with 160k miles. She has problems on a cold start. It sounds like she is misfiring, but when I give it gas after a while it clears up and I'll be good to go. I've replaced spark plugs, spark wires, distributor cap and rotor, fuel pump, fuel filter, and map sensor. I also cleaned up the fuel injectors with seafoam through a vacuum line and Lucas in the gas tank. I also have a check engine light for a crankshaft sensor. Could this make it misfire on cold start?
Old Jun 4, 2020 | 03:52 AM
muellersfan's Avatar
Default Re: Help
First focus on fixing this^ issue. There are two different crankshaft sensors -- one inside the distributor (CKP) and one behind the crankshaft pulley (CKF). What is the specific CEL code?
steven83r
Oct 21, 2013 07:21 AM
h_civ2000
35
Oct 20, 2009 04:15 PM
r0858
Feb 18, 2008 10:42 AM
flyguy0086
Jan 23, 2007 10:11 PM
00s2KkId
Oct 27, 2004 02:32 PM
