89 civic random culture and sputtering till shuts down
Old Jun 3, 2020 | 09:59 AM
Coolhikes's Avatar
Default 89 civic random culture and sputtering till shuts down
The car runs fine but occasionally stalls out on my daughter. I noticed first hand yesterday. I checked light under passenger carpet. 4 flashes the 8 flashes. Car is running fine at this moment. Does it store codes or is this the code when running fine?
Old Jun 4, 2020 | 09:48 AM
scelestus's Avatar
Default Re: 89 civic random culture and sputtering till shuts down
https://honda-tech.com/forums/honda-...0-ecu-3097979/
See the link above for explanation of codes. The faulty sensors these codes indicate are both located in the distributor. I suggest you check and clean up the grounds first just in case that helps.
If a replacement distributor is required, an auto parts store may be advisable over ebay. It's not cheap, but the warranty could be very valuable.
delmo777
Oct 17, 2012 03:30 AM
EsQueue
Jun 26, 2006 12:32 AM
Tuner Eddy
Apr 9, 2005 06:50 AM
IntegraGSR23
10
Mar 29, 2002 03:17 PM
IntegraGSR23
Mar 29, 2002 09:06 AM
