Road / Race: Testing the 5th Gen: Could not disable ABS
Was testing the accord last week in the rain. Pulling the e-brake one-click to engage the brake light on the dash did NOT disengage the ABS system as it would on a similarly equipped integra. ABS system and kickback was still alive under hard braking to skid conditions. This was attempted different times on different surfaces....
Anyone have similar or dissimilar experiences?
i just looked at your pics of your car where did your get the cage from? i'm looking for one and is it welded on bolted in?
can anyone explain why the abs light comes on if the car is traveling over 40 mph(on speed of course) when its lifted off the ground?
be careful wiht this, you can void insurance and any warranty by messing with ABS, mine is disconnected and it id tricky to learn threshold braking in a non-ABS situation
is there a paticular reason you are doing this?
if you want a cage look at Mitch Piper (PiperMotorsports) out of NOVA. He builds the best cages around.
are you building a road race car?
[Modified by urbanlegend21, 12:27 PM 11/20/2002]
a couple of years ago we had ice storms in the Philadelphia area and at the time I was driving a 93 Grand AM and The entire street was a sheet of ice and I had started braking like 1/2 a mile before the light and the ABS was pumping the entire time untill suddenly the light came on and the car just started skidding sideways, I think that the ABS can't figure out why the car hasn't stopped yet and why whenever it lets off the brake the wheel doesn't start spinning again and it throws a code thinking that one of the sensors is feeding back faluty information. Just a theory.
SO if that is true same thing in a race situation, the wheel is off the ground ABS kicks in the wheel stops but all the other wheels are still moving , but yet that one wheel hasn't started spinning again, confuses the ABS.
your point makes sense though because some smaller civics and CRX's will lighten the rear wheel under extremely hard braking, but I have never seen it so much the wheel will not keep spining, or it be for more than a split second if that
Pulling the ebrake up does kill the ABS in Accords. I have done it before. You have to drive around for certain amount of time (30secs?) then the ABS light will come on. I've done it a few times, just goofing off.
