honda civic sedan rust problem
hi guys, i have an issue on my ek4 sedan with the rust under the right rear flloor , close to the rear wheel. The guy at the workshop told me i can loose the rear right wheel beacuse only two screws are holding it , now i dont know if hes overreacting, the rust there is bad beacuse its a small holl there close in the floor.
Can this be fixed?
Can this be fixed?
Can this be fixed?
Can this be fixed?
Either your studs are trashed and your hub holding the rear wheel is toast OR you're talking about the rear wheel well/arch area.
As for the rust on the floor, it really does depend on just how bad it is. You would really need to pull the carpet and get underneath it to really see how extensive the damage is. With rust you have to make sure you get it all out and stop it before it becomes too late. If your able to get rid of the rust and have the proper bodywork done, I'm sure it can be saved.
Strathcona
Honda CR-V & Element
Apr 19, 2017 10:32 AM
1998AccordVTEC
Apr 21, 2014 04:38 PM
kieranmhalton
Jun 11, 2013 05:00 PM
CooBlueDAB
54
Dec 28, 2004 03:29 PM
