Can a bad ECT sensor override the fan switch?
Old May 30, 2020 | 04:24 PM
eg6noise's Avatar
Default Can a bad ECT sensor override the fan switch?
Hi, does anyone know if a bad ECT sensor can override the fan switch? It's known the ECU has a wire labeled FANC (pin A12) but I'm told is not used on stock ECUs. My fan switch is supposed to turn on at 93 deg C and off at 88 deg C. The fan turns on briefly at 93 but turns off shortly when stationary (around 5 sec) and clearly above 88 C (tested with a thermometer pointing to the upper rad hose close to the switch). I have tested with two different fan switches (one known good and other brand new).
Old May 30, 2020 | 06:04 PM
muellersfan's Avatar
Default Re: Can a bad ECT sensor override the fan switch?
Fan switch seems fine as long as your engine is not overheating,
LukieLuc
Jun 12, 2007 05:46 AM
motormike40
Apr 5, 2007 08:23 AM
motormike40
Apr 1, 2007 03:55 PM
diyer
Aug 11, 2004 08:34 AM
GreenD
Sep 15, 2003 12:48 PM
