Windows and Locks Oh My!!!
Old May 28, 2020 | 02:21 PM
stemcellsrock's Avatar
Default Windows and Locks Oh My!!!
So, I have a 98 accord 4 door Ex manual. My sunroof was leaking so I removed all of the interior, replaced the carpet, and fixed the leak. In order to access the leak on the passenger side I had to remove all but 1 of the wire harness connections in the inner door fuse box panel on the passenger side. While in there I replaced the cabin air filters as well. I put everything back together, and now the power locks do not work, the only window that does work is the driver side window. There isn't even a click when activating the switches, so there is no power going to the windows or locks. All of which worked before doing the work. While working I disconnected the battery, so I don't think I could have shorted anything out. I have triple checked all of the connections that I unplugged, and they are all plugged in. All plugs went in smooth so I don't think a pin was bent but I am going to check that next. I have read that there is a master regulator in the driver side door, and it may be asleep. However, the reawakening procedure has not worked. I have no experience with electrical stuff. If anyone has experienced this, or has any thoughts or suggestions I would appreciate any advice. Cheers.
Old May 28, 2020 | 04:45 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Windows and Locks Oh My!!!
Check passenger under-dash Fuse No. 13 (7.5A).
Old May 31, 2020 | 10:20 AM
tech8, thank you for your reply and sorry for the delayed response as I have been occupied elsewhere. Per your suggestion I replaced that fuse as well as a couple of others related to the window systems. It did not solve the issue. If you have any other input I would appreciate any advice you may have.
Old May 31, 2020 | 06:53 PM
99stockcivic's Avatar
That kinda sounds like an issue with the multiplexer ., maybe you knocked it loose? Or it got wet.
Look at this image and you can see where I am talking about
http://www.2carpros.com/forum/automo...ultiplex_1.jpg
Old Jun 1, 2020 | 07:29 AM
99stockcivic, through my reading I am leaning in that direction as well. I am going to check the power in and out of the multiplexer next. I am also worried about having potentially damaged the wiring harnesses in the passenger side fuse box. Thank you for your input. I will let you know how it goes.
Joey Mitchell
Apr 13, 2019 11:58 AM
pdubbs
Jun 18, 2016 06:02 AM
JDMEMone
Jun 28, 2012 08:37 PM
Snailor Built
Jun 14, 2010 07:13 PM
acracer2008
Jun 4, 2010 05:36 PM
