Main Relay No Power D16z6 (zc imported motor)
My main relay is receiving no power at all from the ecu. I don’t know how to test that with the ecu. I do have a multimeter. Since the main relay is getting now power the fuel pump is not turning on but my relay and my pump both work and yes I tested them. When I turn the key the heater relay clicks loudly. All the grounds are good except the thermostat ground has no continuity
Update: the thermostat housing now has continuity with the grounds for ecu. Still no progress.
Last edited by Nicolas Garcia; May 26, 2020 at 01:50 PM. Reason: Update: The thermostat
I replaced the ignition switch and everything worked perfectly. I went to check to see if the fuel pump was pumping gas so I disconnected the negative terminal and put it back after troubleshooting and the problem came back. But this time the ignition switch is perfectly okay. There is continuity for each turn. All fuses are good also. Any help is appreciated. I like to note that only one wire has constant power. Another wire only has 6v unlike the constant has 12v.
Possibly the ECU. Is the check engine coming on and staying solid as soon as you put the key in ACC? Normal operation is CE light on then off along with the main clicking and fuel pump priming
Well now when I turn it to crank the engine light stays on
