Goodridge rear stainless brake lines for 92-95 civic don't fit?
As you can see, the brake line end on the caliper side doesnt have the appropriate angle to allow the brake line to route around the trailing arm/shock bracket. Anybody else have this issue? I tried swapping brake lines side to side and same issue.
Have you tried taking the brake line off and attaching it to the caliper first?
From the looks of it it looks like it will work. Remember that because the line is made to bend for easier installation it can be attached to the caliper then
Try that and let us know if it works out.
Thanks, so I did get it to work however the fitting should have been made a little more angled. The brake line is pushed up against the trailing arm pretty snug, probably won't impact anything since there won't be movement there but seems odd. Design needs a bit of improvement..
