91 CRX p28 Hondata no power to ECU - Main relay is fine!
Old May 24, 2020 | 09:17 AM
Kryptic1333's Avatar
Default 91 CRX p28 Hondata no power to ECU - Main relay is fine!
P28 with hondata shut off while driving and no power to ecu now. I know my ECU has no power because I cannot see any lights on my hondata and it stopped communicating with my computer. I have gone through replacing all ecu capacitors and renewing thermostat and transmission ground wires. I also tested and re soldered my main relay just to be sure. I did find that if I unplug the C connector at the ECU I hear the fuel pump kick on and my hondata lights up. I cannot start the car because of all the sensor that connect to the C connector but at least I know that is the issue. I now have to go through each wire and figure this all out. Recently I just removed and replaced my transmission so I am wondering if that had anything to do with it. Anyone know what might be causing no power to ECU only when the C connector is connected? Thanks for your time!
P.S. ALL dashboard lights come on when key is on and stay there. No check engine light flashing or going out once test is complete. All the lights stay on as long as the key is in on position.
t-too
Apr 27, 2012 10:00 AM
Pinoyjava
Dec 11, 2005 08:32 PM
99B16Si
Sep 29, 2004 06:53 AM
