Belt or bearing?
Old May 23, 2020 | 05:17 PM
angrysmileyface's Avatar
Default Belt or bearing?
So In trying to track down the vibration of my engine (1995 accord ex)
My engine has decided to make what could only be described as a warbling tone.
Old May 24, 2020 | 05:39 AM
Fitz Williams's Avatar
10 Year Member
Default Re: Belt or bearing?
Sounds like a bearing (not main or rod). Maybe, PS pump, alternator, AC, distributor. A stethoscope would help if you have one.
Old May 24, 2020 | 02:00 PM
I tried listening with a pry bar (couldn't find my mechanics stethoscope, ) but I really didn't hear much more than what I'd consider rolling noises.
Old May 24, 2020 | 03:51 PM
MAD_MIKE's Avatar
MM Gruppe B
Is it MT or AT?
Have you stuck your listening stick down on the trans case? Might be a bad throwout bearing or input shaft bearing.
How does the crank pulley look?
Old May 24, 2020 | 05:35 PM
automatic, no clutch bearings to sing
Old May 24, 2020 | 06:01 PM
MAD_MIKE's Avatar
MM Gruppe B
Did you put your stick on the transmission anyway?
Could be something in the TC or pump issue.
It does sound like the PS pump is not happy, but you stated it wasn't making any noise.
Have you run the engine with the belts off to see if the noise goes away?
Old May 25, 2020 | 05:09 PM
99stockcivic's Avatar
Agreed, take the belt off. Then you can also spin each item by hand to see if the alternator or power steering are making the noise and eliminate if they are not.
You could also jack up the car and turn the motor by hand if interested by a socket at the crank.
BLKFLSH
Dec 20, 2011 11:30 AM
hondaccordexvl
Dec 30, 2008 07:46 AM
beansieboi
May 10, 2006 05:19 AM
e_r_i_c_
Apr 22, 2003 07:02 PM
