A25-12v/B1-0v/ no continuity A26 or B2/map sensor lead 5-v
Old May 22, 2020 | 08:43 AM
Spinit's Avatar
Default A25-12v/B1-0v/ no continuity A26 or B2/map sensor lead 5-v
D15B7... intermittent fuel pump signal
any help would be appreciated
Old May 22, 2020 | 12:32 PM
b_boy190's Avatar
Default Re: A25-12v/B1-0v/ no continuity A26 or B2/map sensor lead 5-v
Give us a little more information. Like, what have you done to track down the problem, when did it start, what was recently done to the car?
Info like that can help us help you.
Old May 22, 2020 | 01:14 PM
Spinit's Avatar
It's virgin no mods...I changed the the two 15 amp fuses in both boxes...I cleaned the ground wire on the thermostat housing...I replaced the relay with a know good one...I get an occasional signal from the relay to the fuel pump and it starts...It sat for a few months, I've owned it for 8 years and have never had a problem...all I've ever done was replace the battery and years ago put new shocks in the front
i don't what else to do...
Thanks for the reply
Old May 22, 2020 | 08:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Power capacitor problem within the ECU...
Old May 23, 2020 | 04:41 AM
Spinit's Avatar
I called a friend and he said he'll see if he can solder in a new capacitor...thank you...
Old May 25, 2020 | 07:31 AM
Spinit's Avatar
I was able to borrow a friend's ECU and still no fuel pump signal. I jumped A8 to ground and the fuel pump doesn't run/ no signal either.
i noticed today that a small amount of water was leaking on the cover of the fuse box in the engine bay and dripping down the back toward the firewall.
Thanks in advance for your help.
96ekb20v
Jun 12, 2008 12:20 PM
methos713
Jun 11, 2007 12:43 PM
