Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2010 Civic AC issue
Old May 21, 2020 | 06:35 PM
jddhonda's Avatar
Icon5 2010 Civic AC issue
Hi all, first time on this HondaTech site. I have a 2010 Civic that's having an AC issue. When I press the "AC" button on my dash, the compressor clutch isn't engaging. I've checked pressures and it looks like I have sufficient pressure. I even tried recharging the system before I realized that the clutch wasn't engaging.
One question I have - if the compressor is bad, will the clutch still engage? I want to verify that it isn't the clutch.
Another question - is the clutch going out common?
Another question - can you replace the clutch without removing the radiator? Can it be replaced without removing and recharging the refrigerant?
Thank you ahead of time!
Old May 23, 2020 | 06:19 AM
Audripulls's Avatar
Default Re: 2010 Civic AC issue
Did you try swapping in a new a/c relay ?
If the system is too low on refrigerant the compressor will not engage .
Old Jun 4, 2020 | 05:49 AM
spenceyd's Avatar
I agree with Audripulls. I'd replace the A/C relay. Mine went out after a compressor install and it fired right back up. Clutch won't engage for a couple reasons. A/C Relay, compressor is shot, lack of refrigerant. There may be other reasons but I'd start with the A/C Relay. I bought mine of Amazon for $20.
Old Jul 2, 2020 | 08:26 PM
muellersfan's Avatar
If the condenser fan runs, try tapping the face of the compressor clutch with a rubber mallet. If this causes the clutch to engage, then the air gap may be too large and the clutch just needs to be re-shimmed.
AZCR-V
Honda CR-V & Element
Apr 23, 2018 07:58 AM
