TIP: Upper radiator hose (1x1.25)
Old May 20, 2020 | 01:11 PM
NVturbo's Avatar
O.G. triple O.G.
Default TIP: Upper radiator hose (1x1.25)
in case you end up with an aftermarket radiator that has a 32mm (1.25") upper hose neck, this particular Gates hose will work. Meaning....you have a SOHC engine.
I would advise using new adjustable clamps at both ends. Part number is in the picture.
Old May 20, 2020 | 02:36 PM
tony_2018's Avatar
Fish Twig
Default Re: TIP: Upper radiator hose (1x1.25)
looks bloated af.
Old May 20, 2020 | 03:15 PM
chrysler kid's Avatar
I've never had a problem slipping a d-series hose over the radiator outlet for the b-series
Old May 20, 2020 | 03:44 PM
NVturbo's Avatar
O.G. triple O.G.
Originally Posted by tony_2018
looks bloated af.
it does..doesn't it? No worries. It's a new hose. Hope you do realize the ends are different sizes...hence 1x1.25
this is the easiest method instead of trying to massage the stock D series hose onto a 32mm hose neck. Plus, the hose only costs $12, not $50+ for some silicone one.
Old May 20, 2020 | 04:57 PM
stock hoses fit fine for me too
Old May 21, 2020 | 02:46 AM
NVturbo's Avatar
O.G. triple O.G.
what's the size of the upper hose neck on the aluminum radiator? ^^^
I had a brand new hose from Honda and it was a PITA to fit mine. That's why I had to look for one with a 1.25" opening on one end and 1" on the other.
Old May 21, 2020 | 06:53 AM
Freedo_Civegra's Avatar
Good find. What about those rubber hose adapter inserts?
Old May 21, 2020 | 07:38 AM
It was for sure larger than the original radiator neck. I had to use some oil from the dip stick on the radiator neck and slide the original hose over it.
Old May 21, 2020 | 11:45 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Nice find!!!
Old May 21, 2020 | 03:53 PM
NVturbo's Avatar
O.G. triple O.G.
I have not seen one that goes from 1.25" to 1". That's why I had to look for the formed hose from Gates' website.
Old May 21, 2020 | 04:26 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
One thing about worm clamps is you have to remember to snug them up every so often as the EPDM rubber compresses.
It's my understanding why spring clamps are used by manufacturers, less messing with over time. Spring naturally tightens as rubber "shrinks".
Old May 22, 2020 | 03:37 AM
Premium Member
Loved
Community Favorite
Performance Radiator includes them with EG Civic rads. That way no sep part # for the B16 del Sol...
Old May 22, 2020 | 08:56 AM
tony_2018's Avatar
Fish Twig
I've had to do this for the mishimoto radiator as well. I will have to replace sooner than usual. Not suppose to stretch it this much.
Old May 22, 2020 | 04:05 PM
NVturbo's Avatar
O.G. triple O.G.
Good point. The one I use is pretty decent and I haven't had to adjust it.
Old Feb 1, 2021 | 03:28 PM
adiDAs's Avatar
What about the lower hose? Doesn't that one also have a bigger neck on the aluminum rads?
Old Feb 2, 2021 | 11:29 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I don't think so. I think the B series only the upper hose was larger, go figure.
Old Feb 2, 2021 | 07:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Both hoses are the same size. "B" series hoses are 1/8" larger in diameter than "D" series hoses.
Old Feb 3, 2021 | 07:23 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Good to know, thank you for the correction. Better to have proper information available.
killumanti
Apr 8, 2009 11:27 AM
Slvr_CRX
Apr 8, 2004 09:03 AM
sloweh3
Feb 17, 2004 04:32 PM
Sam268
Nov 3, 2003 09:12 AM
