95 Accord Injector Problem
I've got a 95 accord that I cannot get to start. I've swapped out the fuel rail and all injectors, ecu and main fuel relay.
I have fuel to the injectors, but only 1 is opening to spray fuel (the other three are not getting a pulse).
Any help or suggestions is appreciated.
If you have swapped out the rail, then you need to check voltage to the injectors. If they are not getting it, you need to check grounds on the car, such as the one to the manifold. Often that is the issue.
Give me some insight into how you're measuring voltage. For example, where are you touching (1) the meter's red lead wire to and (2) the meter's black lead wire to?
If you're getting voltage (+) to only 1 injector and not the other 3 injectors, then you may have a faulty injector resistor or an open (break) in the wire harness or connectors that go from the injector resistor to the injectors. (Power is fed through the injector resistor to the injectors.)
Thank you so much for the help
S1NFUL RL1 619
Jul 1, 2010 09:27 AM
