Passenger & back windows not working!
Old May 18, 2020 | 05:51 PM
Trizte's Avatar
Default Passenger & back windows not working!
Did anyone ever figured out why all 3 windows stop working at the same time!? I ran into that problem around a month ago but before that I had my drivers window relay damaged for 4months, I didn’t have the money to fix it with a professional $280 home service, or $169 DIY, so I drove the car like that until it began to 🌧, So i went old school! I began researching online and read a few posts on google, i tried most of them but the one that worked and didn’t have to spend a penny was un assembling the door panel and getting to the window motor out, once out I got a wrench and banged it a couple of times then installed it back and WALLAH it worked!! But then a month after the other 3 stopped working! It sounds like the motors are forcing themselves. Does anyone know how to solve this one, i hope its better than repeating the steps i did on the driver side
Old May 18, 2020 | 06:04 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Passenger & back windows not working!
You didn't list what year and model car; but, I would guess you probably have a 2003 - 2007 Accord based on your problem. This sub-forum is for 1990-2002 Accords.
Old May 18, 2020 | 07:51 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Post the year and model, if it is a 2003-2007 Accord, it is likely due to a faulty driver's door multiplex control unit. There are tests that can be done to confirm. If it is faulty, it can be replaced or some terminals jumped if you don't want to replace.
Old May 19, 2020 | 10:20 AM
99stockcivic's Avatar
The multi-plex gets my vote as well. It looks like this:
Amazon Amazon
It should be on the drivers side under the dash or against the footwell.
I don't know the paperclip trick, so I can't help there.
Old May 19, 2020 | 11:22 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
https://www.amazon.com/Genuine-Honda.../dp/B00P4TH320
That is the incorrect location, part and year if the OP's car is a 7th generation Accord.
flam2828
Jul 21, 2019 01:43 PM
mbeckwit
May 3, 2008 07:25 AM
KetteringITR
Sep 12, 2004 01:07 AM
crazy eyez killa
Sep 7, 2004 10:06 PM
acatak
Mar 28, 2003 04:25 PM
