Crx d16 zc oem si
Hi.
So i am stuck now trying to find the issue with my Car that started some months ago.
It is an 91 si crx, obd0 all stock with d16a9 also known as zc. It is dohc.
Having issues (start after crank and crank over for some seconds and stall right after) with bogging missing fire and a lot of gas smell, decided to change a few things that were the original ones:
converted to obd1 new distributor, ecu, changed injectors for some rebuild ones, new Spark plug and cables, checked timming. Same issue. Had code 9. Rewired that, fixed. Still the same, but now started right after cranking.
the next day, went to the garage, started and died right after, the next 10 minutes no priming, No clicking, no cell light or check light. But Car cranks over, and lights works. Will not come check light for the priming neither. Waited and tryied. Started and stall. After That, Will not start again.
could be some power issue to the ecu, because if it was the pump i would still get the cell for the main relay time as it attemps to prime.
changed to obd0 ecu nothing.
chequed 3 times all the fuses from the engine bay, and under dash, also power going to the main relay proved with a tester.
any advice?
thank you.-
any advice?
thank you.-
redwards
May 24, 2009 01:38 AM
Phils
55
Jun 29, 2007 06:40 AM
BoRiCuA
Oct 4, 2005 04:04 PM
crxzc
24
May 30, 2002 08:26 PM
