Difficult no start 07 civic ex
Engine turns over but won't start. Months ago the head gasket and oxygen sensor were replaced and 10 minutes of driving it the check engine light came back on and gave the same code as before but I don't remember it other that vvt and oxygen sensor. Before I know it I have to stop driving it because the car refused to go faster than 25mph with no accerloration. I have the money to fix it now and changed the solenoid valve hoping that would correct the issue to no avail. The check engine light is on the the key is in the ignition and the oil pressure light. When I try to start it turns over as mentioned but no other noise, then the maintenance wrench pops up for a second and goes away then it becomes the oil light. After some attempts the engine light went away only to return the next attempt.
Any help is appreciated.
mhng
Apr 23, 2005 06:44 AM
